- Adding the FW190 A4 1.42ATA to stock Eastern front campaigns
Level 1Gday
I am searching for infomation on how to do this, Ever since TD gave us the new butcher bird I am stuck flying around the derated 80% throttle model, I want to know how to cange this,
I am using Asuras latest dgen mod
Ta
Kennel -
AdminThis should be easy. The stock Eastern Front campaigns don't use their own xxplanes.dat files for every sub-campaign, so all you have to do is to add the line FW_190A4FR to the planesDexxx file of the campaign you are flying. I think the file is planesDeC, planesDeF or planesDeN. -
Level 1Thankyou Juri -
Main AdminI don?t know if there is an concerning classes file for each of these stock campaigns exisiting, but it would be helpfull to add this plane into a classes file if you want to fly fighter missions only. -
Level 1I tried adding that plane, and all I got was a LOUD beep when staring a new campaign... -
12 years agoFri Jun 27 2014, 03:42pm
Level 1I have found out that the campaign maps only support certain core planes... A lot of the planes you can add, but if you get the loud BEEP, then that is a map that doesn't support that particular plane as a flyable player A/C... Lot of trial and error...I know the few that DON'T work... The Ju-88, the Hs-129, and any FW-190 with the ATA motors. The Tempest is available in offline campaigns, but make sure that you use it from 1944 and later...any earlier and you get BEEPED... -
Level 1Found a better way, SAS MOD ACT & Mission pro for 4.12, problem solved
