- Mission Builders HQ
- The Ops Room
- Problems with installing dgen campaigns?
Main AdminSometimes it?s a little bit tricky to get dgen campaigns work, because there is some stuff misssing in your install, which does not come with the stock IL2 game, but it?s easy to solve the problems.
Here are some examples:
Sometimes you're missing some message files, check these updated message files from vtrelut and install them into the DGEN folder:
http://www.mission4today.com/index.php?name=Downloads&file=details&id=2615
these files often solved problems in the past - if the campaign don?t work, just install these files, it?s worth a try and you can?t do any damage to your install.
For RAF campaigns it can also be a problem with the british ranks and medals, if your RAF campaign in particular does not work try this:
http://www.mission4today.com/index.php?name=Downloads&file=details&id=629
Level 2Thanks Boelcke I will give that a try and let you know
Krys -
12 years ago
Level 1Please please please help, I have a new istall V4.12.2 and HSFX7.2
I've istalled Westfront and Azura Dgen Mod......beep, installed missing files......beep, now getting a missing aircraft error and an inability to delete directory (what ever that means):
= DGen_mod 2.0.1.0 (21/10/2013) =
seed: 173155906
ParamStr: gb 0
DGen_mod initialization. Side: gb, Rank: 0
MaxFLAK=10
MaxBomberSkill=0
Distance=Any
Length=VeryLong
AI=Normal
Missions=Normal
AirIntensity=Medium
GroundIntensity=Medium
SlowFire=1.0
PromotionRate=1.90
Career ID: GbBoe05
Unable to delete directory: missions\campaign\gb\DGen_Boe05_Africa3doe0
EnemyNation from settings: Germany
Load DGen\mod\AllPlaneDB.dat:
Load DGen\Africa3Planes.dat:
Northern_Africa_Jir:NorthAfrica2
Inherits NorthAfrica2
Load DGen\mod\Northern_Africa_JirTowns.dat:
EnemyNation from stock: Germany
ReadDB sorties:1
Load DGen\mod\AllWing.dat:
TestWing(Allies,RAF_No112SQN): RAF_No112SQN 0 00
TestWing(Axis,153Squadriglia): 153Squadriglia 4 10
TestWing(Axis,88Squadriglia): 88Squadriglia 4 10
TestWing(Axis,363Squadriglia): 363Squadriglia 4 10
TestWing(Axis,259Squadriglia): 259Squadriglia 4 10
Cannot find plane FiatBr20
Problem not just with RAF but all dgen campaigns.
any help would be appreciated as I'm loosing my miiiiiind
12 years agoWed Apr 16 2014, 10:54am
12 years ago
Level 1Wundebar!
Thank you very much works fine now. One last little question, Briefings are in Russian, how do I change to English please? -
12 years agoThu Apr 17 2014, 09:56am
spiteful21k
Wundebar!
Check the dgen_mod.ini in the IL2 root folder and copy these lines into it before starting a campaign:
[DGen_mod]
LogLevel=2
RandomFlights=3
MaxFLAK=40
AirIntensity=Medium
MaxBomberSkill=0
CampaignMissions=Normal
CampaignAI=Normal
CampaignLength=Normal
CampaignDifficulty=Normal
SlowFire=1
PromotionRate=1.9
Language=English
11 years ago
Level 1Thank you very much for your help. -
Main Adminno problem, hope to see some screenshots from the campaign soon in this thread
http://www.axis-and-allies-paintworks.com/e107_plugins/forum/forum_viewtopic.php?9276
